Home > Technical (L322) > LED running lights
Page 3 of 3 <123
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Rear ones are though I think... 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #210984 18th Sep 2013 8:27pm
They certainly are. Thumbs Up
Post #210985 18th Sep 2013 8:28pm
klf400
Take a look at my drls I fitted the led rings inside the 2010 fog light ,it is easier to fit them in pre 2010 lights , I think they look discreet inside the fogs and doesn't look like an add on. Thumbs Up
http://www.fullfatrr.com/forum/topic16962.html 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #211227 20th Sep 2013 8:49am
how did you split the fog units? ... - .- -.
Post #211229 20th Sep 2013 9:10am
klf400
heated the lens and body with a hair dryer to soften the glue , you have to get them pretty hot or they wont come apart , to put them back together i used a bead or tiger seal to bed the lens back into the plastic Thumbs Up 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #211262 20th Sep 2013 11:15am
thanks. Thumbs Up ... - .- -.
Post #211295 20th Sep 2013 1:49pm
paneldamage
Hi klf400, where did the rings one from? Lots on the bay, but would like to be sure of getting ones of equal brightness as yours, cheers
Post #211372 20th Sep 2013 8:17pm
klf400
Bought them of eBay last year they came from Singapore , but can't find it in my purchase history , may be able to dig out the package they came in as I bought two sets , one thing to bear in mind is the rings for the 2010 > fog lights need to be bigger than pre 2010 otherwise they will be to big or to small depends on which one you are converting Thumbs Up 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #211413 21st Sep 2013 8:10am
Rich86
I want to fit the long type lights below the headlights so within the grey air dams.
Has anyone carried this out and is it best left to an expert or are they easy to fit? 2009 Vogue TDV8 Nara Bronze
Post #224248 21st Nov 2013 10:00am
Page 3 of 3 <123
