![]() | Home > Technical (L322) > LED running lights |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Looking at adding some bling to my car and adding running lights but not doing the LED headlamp conversion.
I'm not contemplating the cheap ones hence why I'm looking of some advice and images...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Fitting led rings inside tthe foglights is about as discrete as you can get.
Sounds like a plan but the images on the link aren't there anymore so I can't see the end result.
Sorry about that, had a clear out of pictures.
Which first post? Sorry if I'm being thick... 2009 Vogue TDV8 Nara Bronze
Third line down in the link in my first post. |
Here is the link: http://www.disco3.co.uk/forum/topic61097.html?highlight .
Thanks guys. They look ok but how would these be wired and to what? 2009 Vogue TDV8 Nara Bronze
If you go thro my post all the info about wiring and the bits you need is in there. |
Just read it and sounds quite complicated. I'm not that technical so I don't think I'd be any good splicing and soldering wires... 2009 Vogue TDV8 Nara Bronze
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
I think DRLs could be added, if the design was right.... Seen some on a RRS that were set into the bumper, the owner said they were a Phillips item, it is one of those jobs that if done wrong, or poorly executed could really spoil things. You need the factory look....and just sticking them in the slots towards the centre of the car would be pointless and illegal
Do you mean the fogs under the bumper as mentioned above? 2009 Vogue TDV8 Nara Bronze
