![]() | Home > Technical (L322) > IID TOOL & Clearing 'Inspection' Message |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Which iid tool did you use? |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Standard one back when I first did it then I used the IIDTool BT few days ago. |
Bump |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
only guessing but have you thought of a battery dis-connection ? ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
If its anything like BMW, i reckon that The inspection date is written into a non-volatile area of (possibly) several ECUs in the same way that the mileage is, so that disconnecting the battery won't have any effect. Got - 2017 SDV8 Autobiography in Loire Blue
I will give it a go anyway .... Its no major problem, just slightly annoying |
Try the manual approach in the wiki (secret codes) .
yrea tried that - didn't work |
try changing the date on the touchscreen to something after 10/14 then reset it again, then change the date back to normal..
Yea tried changing the date but went backwards, the inspection message then showed 10/13. |
