Home > Technical (L322) > Bad water Ingres problem |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 |
I used to get this with my p38rr,this was down to blocked sunroof drain tubes one way valve in the inner wing was full of crap,once cleared never had the problem again,you could try blowing them through with a compressor but be very careful as this may pop the tube from the sunroof frame. |
22nd Sep 2013 1:38pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Try this :
22nd Sep 2013 2:53pm |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 |
Well I just took my door pillar covers off, the screen looks ok to me, I poured a load of water gently to start through both front sunroof drains both of which threw through, so must be the screen I spose but as I said it looks ok, but I guess I'll get the silacone out!! |
22nd Sep 2013 5:29pm |
I had the same with another car (GMC) that had been repainted and the windscreen had been out. They didn't put it back properly and although it looked fine, I ended up doing the entire rubber to body gap with black silicone before it was a 100% tight.
22nd Sep 2013 5:40pm |
Think I'll pull the pilar guards off and the top rubber thing and silacone the lot!
22nd Sep 2013 9:49pm |
