![]() | Home > Maintenance & Mods (L322) > Handbrake springs |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 224 ![]() ![]() ![]() |
I tried shouting and swearing a lit in front ofvthe neighbours. That seemed make little difference.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Old flat screwdriver with a nic cut out of the blade with a hacksaw? |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Thanks for the advice but I have tried molegrips and a flat bladed screw driver |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
I don't remember struggling with mine.... I seem to recall that I put the springs on while the shoes were outside the slots then used pliers to pull the shoes carefully outwards and onto their seats... Maybe.... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Springs go to the inside between the shoe and backplate
Thats weird - my springs were on the outside |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
Not looking to revive this old thread , but whilst checking for any gotchas before changing the handbrake shoes on my SC I stumbled across this thread ... so it’s possible someone else will too
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Just a thought as I rebuild these brake shoes , I would agree that the springs should be on the outside of the shoes , but the pic shows that I may have them to opposite ends as well. They are quite easy re a video I watched when it comes to stretching the top spring in The bottom one would be my choice . So is the pic upside down as well.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
The pic above your post dating from 2013 is upside down and probably reversed!
Many thanks , reassuring , that’s great , no epb procedure on this one, old fashioned adjust. |
Even better. ![]() The cable attaches into the hinged part, doubt that you could even get it down to the bottom of the assembly. see: http://allbrit.de/LR.cfm?SPRACHE=EN for parts schematics. L322 3.6 TDV8 Vogue. 07MY ML 320 7 Seat full leather etc. (The Black Pearl) ![]() |
Ah that’s better...“allbrit “! |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Have a look at this
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Did mine last weekend in a blizzard - even with all the stars and planets aligning, getting the top spring on still requires a great deal of force.
