Home > Maintenance & Mods (L322) > " air sus inactive after brake change " |
You need to turn the steering from full lock to full lock at least once to reset it. |
27th Sep 2013 7:55am |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 |
hi
27th Sep 2013 7:59am |
^ Yes I see you did it twice... |
27th Sep 2013 8:03am |
Did you move/break/interfere with a height sensor when you where changing the pads? |
27th Sep 2013 8:04am |
sorry fella...still trying to find my way about on here... |
27th Sep 2013 8:09am |
Have you checked the height sensors in the wheel arches? |
27th Sep 2013 8:12am |
not that i can remember, that's something i haven't checked..just getting ready for work but i will have a butchers when i get back...i hope its something as simple as that,fingers crossed... thank you for your help..i will get back on here and let you know later on today.. cheers |
27th Sep 2013 8:15am |
Get the codes read as this should identify the problem including the sensors. |
27th Sep 2013 8:30am |
hi everyone,further more to the ongoing saga,i got home this after noon and turned the steering wheel full lock one way and then other so i had a good view of the level sensor,i had a little prod to see if anything was loose or broken but both are attached to the lower suspension arm and both have the electrical connector connected to them..in regards to the codes that would enable me to find the problem how do i get them to come up up as i don't have a iid tool...any suggestions anyone.. |
27th Sep 2013 5:00pm |
might try jacking up the vogue one side at a time again and hopefully the weight of the wheel assembly will drop the front suspension and reactivate it,,my last hope... |
27th Sep 2013 5:47pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
to save your time and muscle power
27th Sep 2013 10:54pm |
i'll take your word for it and save myself the time and effort of jacking the range up yet again but whats the easiest way to get the codes,don't tell me i need an iid tool.. |
27th Sep 2013 11:09pm |
RSW All Comms, Hawkeye, Faultmate, Solus, TESTBOOK or an IIDTool
28th Sep 2013 12:53am |
Any half/decent code reader that supports BMW group will do
28th Sep 2013 6:39am |
