![]() | Home > Technical (L322) > Egr |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698
Hi Jason.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
If its covered under warranty, you might consider an independent. I was quoted £600 to replace both a couple of weeks ago. Got - 2017 SDV8 Autobiography in Loire Blue
| Jason1608 Member Since: 01 Oct 2013 Location: Leicester Posts: 21 |
Thanks for quick reply did your oil level drop because of the problem. |
| adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204
they should be able to tell from fault codes - or dynamic test
Thanks for advice would dread to think of cost if turbos were broke. Would have to find Indy to do it |
The Indy I use only suggested I replace mine and only as a result of investigation a noise I was hearing. No drop in oil level.
