Home > Technical (L322) > Electric seats and steering control fault |
I'd check the connector to the ECU under the drivers seat first. |
4th Oct 2013 9:03pm |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 |
and now the radio has stopped working great for owning car 1 week |
6th Oct 2013 8:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34922 |
is the battery ok? ... - .- -.
6th Oct 2013 8:48pm |
battery is pretty new,, it happens after driving for a while like something is over heating, now stereo/radio has turned off |
6th Oct 2013 8:50pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i think the radio is something different, on the driver seat is the electric switches loose, the multi plug on the switch pack will cause both them probles if loose there or under the seat as stated. V8 facelift Range Rover Autobiography 22" wheels.
6th Oct 2013 9:02pm |
I have had a fiddle with connector do you mean under the seat or on the side ????
6th Oct 2013 9:07pm |
try the plug on the side of the seat behind te switch valance,
6th Oct 2013 9:14pm |
nothing works both seats and steering adjust then tomorrow it might work for a while then off again , radio cd has gone off also |
6th Oct 2013 9:15pm |
seat and steering adjust was the wiring to the back part of seat for lumbar due to being crushed and split , it actually caught fire bellowing smoke out so careful if this happens to you, all fixed now , coolant light fixed it was sensor £9,00 for that just oil leak and bodywork imperfections then happy days ,,,, for a while |
10th Oct 2013 5:59pm |
