Home > Technical (L322) > Message: "CHECK SIDELIGHT" ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Comes up on start up, turn on sidelights, get out and check, all working.
30th Sep 2013 7:28pm |
Joe its the "Bling" warning mate.... |
30th Sep 2013 7:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
those errors normally come up when theres a faulty bulb or a non-canbus bulb fitted..i suspect that one or both bulbs have burnt out their canbus circuit....or the bulb just needs re-seating. ... - .- -.
30th Sep 2013 8:35pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
+1 for ^ |
30th Sep 2013 9:37pm |
Thanks guys, I'll have a play tomorrow .
30th Sep 2013 10:02pm |
Had a chance to have a look. It was both LEDs, whether they have both gone at once, or it took both to trigger the fault, but see from the picture where the problem was:
5th Oct 2013 11:14am |
i've brought a fair amount of leds/smds and nearly all get dry joints within months of use, but a quick dabble with a soldering iron and they work ok again... ... - .- -.
5th Oct 2013 11:28am |
Stan recommended them (the ones in the photo)
5th Oct 2013 12:04pm |
i did
5th Oct 2013 12:23pm |
The bulbs I used are very bright, almost brighter than the H7s in my foglight DRLs, don't give a canbus message, but blink every 20 seconds or so (this must be the canbus test) .
12th Oct 2013 4:39pm |
you can switch off the hot monitoring with an IIDTool, but you probably knew that already.. ... - .- -.
12th Oct 2013 4:44pm |
Always too embarrassed to ask what hot and cold monitoring is .
12th Oct 2013 4:46pm |
thats when the ecu checks to see if the bulb is ok..cold on start up and hot whilst engine running..
12th Oct 2013 4:54pm |
