Home > Off Topic > Advice needed on home audio setup please |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
I have a pair of Bose Acoustimass speakers which I used to have connected to an old Pioneer stack system. Since putting the Pioneer into retirement, I've got no way of powering the Bose as they need to be connected to an amp.
3rd May 2010 8:27pm |
doublejay Member Since: 08 Nov 2009 Posts: 131 |
bit of minefield noddy without more info....budget, connectivity requirement etc. I will say that the small units from Denon or Onkyo a very well thought of and not a lot of dosh
4th May 2010 9:41am |
I'm led to believe it needs an amp to run. There's no power supply to the sub module ( unlike later versions). It just has speaker inputs which are the clamp type. It might work, but I've never tried it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
4th May 2010 9:54pm |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
An Onkyo amp is great value.
5th May 2010 8:46pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Noddy, which if they're not active Acoutimass speakers (hence why you need the amp), then could do with knowing the model versio or the RMS & peak power handling along with the impedance (i.e. 4/6/8 ohm) etc. of the speakers. It's then easier to match an amp to them with this info. Steve
9th May 2010 12:35am |
How do I find that info out? Is it on the bass box? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
10th May 2010 3:17pm |
Speakers normally have a model number on the back on a sticker, often near the terminal connectors. If it doesn't have the wattage and impedance, can usually get the specification by googling the model number. Steve
10th May 2010 4:28pm |
