Home > Technical (L322) > knocky suspension? |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Change the droplinks my car is the same age as yours and the bushes on the droplinks were perishing these tend to make a knocking noise when going or gone that was at about 72K miles. Change for genuine if you can not expensive so worth doing anyway as tighten up car. Literally 10 mins a side . Rears longer due to access being tight but easly doable.
14th Oct 2013 9:46pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
Mine had exactly the same.
Lower ball joints look tight, no evident movement, so arb links first.
14th Oct 2013 9:57pm |
Does any one kkow who makes the lr ones?
14th Oct 2013 10:04pm |
Pretty sure Delphi are the OEMs thats what I fitted very good quality compared to cheapo versions I have seen. Present :2008 TDV8 HSE
14th Oct 2013 10:34pm |
Cheers Connor. Will have a ring around to find a set. There is nothing that can't be fixed with a hammer😜😜
15th Oct 2013 7:41am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Had a knock on the front of my VSE replaced both lower ball joints with delphi units as there was visible movement on the driver side.
15th Oct 2013 1:02pm |
At the dealer at the moment. They have put it on the ramp to have a look. There is nothing that can't be fixed with a hammer😜😜
15th Oct 2013 5:03pm |
Hokey day, garage reckon the same.
15th Oct 2013 6:08pm |
Ok.
16th Oct 2013 6:03pm |
Part number
16th Oct 2013 6:09pm |
