Home > Technical (L322) > First post!!
Page 3 of 3 <123
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I'm sure you have but I will put my two pennies worth into the thread.....Have you checked the hose right at the back of the engine?? its only about 7 cm long and as you seem to have looked at most things to find the leak may be worth checking Very Happy
Post #219493 29th Oct 2013 11:34am
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I haven't mate as the leak appears to be from the front but I'll try anything!! I'll see if I can find the pipe you speak of on RAVE.
Post #219495 29th Oct 2013 11:37am
paul271
Yes Kurt rads all good. I've a sneaky feeling it's between the pump and the block or the pump and the thermostat.
Worst case they'll get yanked and sealed!
Post #219496 29th Oct 2013 11:40am
paul271
Tomorrow I shall hopefully do battle with "The Leak" again! His days are numbered!
Post #221066 6th Nov 2013 2:48am
srpara
By the looks of that kit you are going to give (him) an enema
Whistle Whistle Whistle
Post #221111 6th Nov 2013 11:43am
paul271
Thought I'd put up the picture from the "other" picture folder there! Shocked
Post #221120 6th Nov 2013 11:56am
Page 3 of 3 <123
