Home > Maintenance & Mods (L322) > Couple of Q's on 2006 conversion |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
In the middle of said conversion at the moment and have a question about the headlamp mounting. The 2006 Xenons I have to fit have the vertical tabs at the top - however the lights from my 2004 that I removed were fixed horizontally with flat tabs on top. How do I fit the new lights? I cant find any pics on this or other RR.net sites to show that bit.
22nd Oct 2013 2:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34943 |
according to the how to in the wiki , you need some headlight mounting assemblies,
22nd Oct 2013 2:17pm |
I have those brackets but they are steel brackets next to the rad and dont appear to have anything to do with fixing the top of the lights.....
22nd Oct 2013 2:22pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Just guessing but do you need the new type wing brackets due to light being different shape. These fit to the inner wing and have holes for fixing of light .I had to replace these doing 2010 conversion so its likely these need replaced ? Present :2008 TDV8 HSE
22nd Oct 2013 3:16pm |
these are a couple of pics of my lights [2008]
22nd Oct 2013 3:23pm |
oooow that looks exactly what I need - can anyone provide a part number for the top parts? or even a pic from rave so I can get the parts locally?
22nd Oct 2013 3:39pm |
you could try microcat for the part numbers , links in the wiki. ... - .- -.
22nd Oct 2013 3:42pm |
Grrrr, trying Microcat and they have loads of blown up drawings but none have the bits I need. "On first name terms with my local Dealer......now."
22nd Oct 2013 4:33pm |
is it this part you need,ASW760090/80 [new part number is LR011566/65]
22nd Oct 2013 4:55pm |
i think you need to talk to the man that knows everything about conversions, CAM - TECH - CRAIG...... ... - .- -.
22nd Oct 2013 5:04pm |
Thanks Stan but no thats not the bit I need - I will PM Craig and may make up a bracket for now.
22nd Oct 2013 6:02pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
22nd Oct 2013 8:01pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
I wonder if this plastic mounting piece is available separately? A guy bought a broken headlight off me just to get his hands on this bit......sorry, just seen Paul's post - what he said. |
22nd Oct 2013 11:21pm |
