![]() | Home > Technical (L322) > Steering column tilt problem |
| Scorchio Member Since: 28 Apr 2010 Location: Staffordshire Posts: 24
Just bought a 2003 Vogue 4.4 ... will post pics after I've given it a nice polish !
| DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148
Odds on, its jammed not broken. There is a nut on the end of the worm gear that tightens and then prevents it from turning.
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
Rather than start a new thread on this - does anyone know how to lubricate the column? Mine makes a noise when its retracting when switched off. Sounds like it needs oil. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Oh forgot to mention - mine does this too ! 2003 Vogue 4.4
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77
I used a long artist's brush about 1/4" wide with grease on it and lubricated the screw mechanism. Noise gone.
| SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 17
If lubing the screw thread doesn't work, try a small squirt of WD40 (or teflon spray) on the bit where the shaft turns by the motor end, (you can see the spindle spinning round there), as these tend to cause the eek, eek eek noise. You know when you have found the right bit as the noise goes away |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
This is a great post guys but some pictures would be very useful for everyone...anyone got any of the work? Discovery 4 HSE
| CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60
This is not really maintenance but shows what happen when mine actually broke, the metal tab snapped |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Funny this thread should come along, I freed mine off last week, I forgot to take some pics as I was going to do a 'how to'.
| doublejay Member Since: 08 Nov 2009 Posts: 131 |
..wait, are we saying there;s more adjustment available if you tweak underneath ? |
Don't know abuot extra adjusment, but if I lower mine right down, it crushes my legs |
I'm being v lazy now- how do you get at the mechanism to lube it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
There's 3 torx screws on the under side of the shroud, the top 2 should be esy enough to get at with uninsulated torx screwdrivers, but the one at the bottom by itself is tucked right in, I found a couple of 3/8 extensions from a socket set with a torx bit on managed to reach it no problem. Once the screws are out, lift the top section up and outwards (If I remember rightly!!) The lower one will drop down too, then lookin up from underneath the steering colum, the spindles are right infront of you.
