![]() | Home > Technical (L322) > Squeek when wheel turns |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698
Well off the garage for sure for me then! |
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
It depends on how tight the ball joint is after 6 years stuck in the hub mine was nealy welded in place. The spanner method didn't work for me and I was close to giving up on the ball joint splitter. Normally I end up with the problem of trying to remove the nut from a ball joint that has started to spin.
£264 to sort. FFS this thing drives me mad. |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
I have been having some issues with my car despite having bushes replaced . I had the the track rod arm on the drivers side replaced . I thought it might have been down to my Alignment being out and it is but obviously the below exaggerates and explains why I have been fighting to keep steering wheel centred in addition to loss of smoothness and stability. Dropped into a garage to get it checked the guys seemed instantly knowledgeable about Range Rovers which is rare in Ireland. They put car up on ramp and checked all bushes arms and noticed that there was play on the drivers side front. They traced it to the track rod arm that had been replaced . As referred to earlier in this post the monkey who replaced it obviously tightened nut on arm whilst car was on ramp leading to bush twisting and therefore prematurely failing on the chassis end .Really |
I feel your pain, seems the motor industry (and building industry to add bitterness from my side) are very badly regulated. No one seems to audit work that leaves garages, seems any knob end can buy ramps and spanners and set up as a business. Im lucky to have found a good independent which are sometimes rarer than an honest car salesman! |
| All times are GMT |
