Home > Technical (L322) > Squeek when wheel turns
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Well 3 weeks since the last problems so about due a faulty. Bloody things are built shockingly.
Anyway, when I turn my steering wheel to the right the car makes a horrible almost corroded rubber bush noise. It's like a creak but sounds like something's about to fall off. Any ideas what it could be?
Post #219083 27th Oct 2013 4:14pm
adigorn
Lower ball joint
Post #219085 27th Oct 2013 4:40pm
crookedm
Funny you say that I've had the drivers side one replaced and when I steered to the right I don't hear a noise but when I steer full lock to the left the noise occurs. That's not been replaced. Ah cock. Back to the garage!
Post #219088 27th Oct 2013 5:39pm
Just actually looked at rave cos there seemed to be a bit of play in mine and it looks fairly simples to change whole arm is about £70.00 and is held on with two bolts. I am fancying a bit of on drive spannering to swap mine over in the next few weeks.
Does anyone know if it will throw the tracking out too much and if so will a high street tyre shop be able to reset it There is nothing that can't be fixed with a hammer😜😜
Post #219109 27th Oct 2013 7:08pm
crookedm
Yes looks simple doesn't it but I guess half the battle is having the right tools. Plus if I cock it up I'd be devastated!
I know its not a warranty job so it's off to a garage tomorrow. Need to buy a trolley jack and decent tools to be fair. If anyone's wirral based or north west and knows what they're doing I'd happily pay them Very Happy
Post #219129 27th Oct 2013 8:11pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Done both mine a couple of weeks ago, it is a simple job if you have a good jack, axle stands and a decent socket set, some ring/open ended spanners and a ball joint splitter.
Only problem I had was splitting the ball joint, needed about 10 good belts with a 20lb sledge hammer as it was tight.
There is a good how to guide in the Wiki (or somewhere on the forum) 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #219144 27th Oct 2013 8:53pm
crookedm
Ah poo I don't have any of those tools!!
Post #219145 27th Oct 2013 8:58pm
When you watch ed china split a ball joint it takes a tap with a lump hammer.......
What a load of Censored
Don't have a splitter but they are cheap enough! There is nothing that can't be fixed with a hammer😜😜
Post #219168 27th Oct 2013 10:08pm
Ed China's a real mechanic Shocked Laughing Laughing Laughing
Post #219179 27th Oct 2013 10:23pm
What do we expect
The man builds motorised desks!
Cool motorised desks though Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #219181 27th Oct 2013 10:24pm
crookedm
Who is Ed China?
Where do I get the rav or rave from?
Post #219188 27th Oct 2013 10:40pm
http://www.fullfatrr.com/forum/topic17623.html?highlight=i
Have a look at that for rave. might still work.
ed China is a TV mechanic/wheeler dealers, and builds motorised oddities. There is nothing that can't be fixed with a hammer😜😜
Post #219190 27th Oct 2013 10:44pm
crookedm
Ah I have that forgotten all about it!
Found this to. I'd definitely cock it up!
http://www.fullfatrr.com/forum/topic1632.h...suspension
Post #219194 27th Oct 2013 10:50pm
Googsy
No reference to splitter in above post? Is it really needed if replacing complete arm as in link above. Seems very straight forward. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #219219 28th Oct 2013 12:53am
The above post isn't the lower ball joint it's the transverse link, the balljoint is behind that link
Post #219223 28th Oct 2013 12:58am
