Home > My Range Rover > 2006MY SC - Spec
Vogue
As per Polux all genuine AB's should have the LR plate
Post #219468 29th Oct 2013 10:26am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Joker - Yep, you're spot on. Many thanks.
CG-SC - Your SC (like mine) has to be a Vogue SE then - That's all that was made for 2006MY. AB didn't arrive until 2008 onwards.
I've been up into the loft and dug out some old What Car? magazines which backs this up........
May 2005 - LR introduce AJ-V8s
September 2005 - SC is only available in Vogue SE spec
November 2006- SC is STILL only available in Vogue SE spec (4.2V8 Overfinch Supersport appears for a couple of months at £102,488) Shocked
SC AB appears 2008 +
That clears that one up then! Thanks all! Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #219469 29th Oct 2013 10:28am
SKOT
Polux wrote:
check you have the autobiog plate under the bonnet at the front, should have your AB registered number
I'm almost sure it doesn't - So that doubly confirms that it is not an AB! Thanks! 2006 4.2 SC
Post #219470 29th Oct 2013 10:37am
SKOT
Excuse the dirt........This is what threw me of the scent........I really wish people wouldn't do this stuff!! Twisted Evil
 2006 4.2 SC
Post #219471 29th Oct 2013 10:47am
the rear badge on your scab Mr. Green is proper like mine , the tread plates are not ..
mine,
Post #219474 29th Oct 2013 11:08am
Welshdragon
Come on Stan you could of at least polished the scuff plate shinny and hidden the snot rag, I mean tissue away Twisted Evil If it dont work.......burn it!
Post #219563 29th Oct 2013 8:05pm
Embarassed yarp the plate does need polishing..
the snot rag was used to clean the lower plate ready for the protective wrap.. Thumbs Up ... - .- -.
Post #219573 29th Oct 2013 8:44pm
Welshdragon
Rolling with laughter Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #219583 29th Oct 2013 9:16pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
The tread plates are both genuine. First ones are just the early version when Autobiography wasn't part of the full model line up and were ordered through Special Vehicles only.
Post #219849 30th Oct 2013 10:00pm
