Home > My Range Rover > 2006MY SC - Spec |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Vehicle built August 2005
28th Oct 2013 9:10pm |
Yes, Dan did that and it's given me pages of extras but nowhere does it actually make reference to Vogue SE...... 2006 4.2 SC
28th Oct 2013 9:34pm |
Annoying. MY 2010 5.0 SC Galway green and sand interior!!
28th Oct 2013 9:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
if it helps ,this is what i have on my AB build sheet so you can compare.
28th Oct 2013 9:45pm |
Thanks both.
28th Oct 2013 9:52pm |
i suspect that the trim level entry in the wiki might not be that accurate.. ... - .- -.
28th Oct 2013 9:59pm |
Ah I see..............Well maybe it is an AB afterall and the AB badge on the boot is correct?
28th Oct 2013 10:16pm |
as in my pm Steve i reckon the 'unbadged autobiography' bit is the answer.. ... - .- -.
28th Oct 2013 10:39pm |
2005 mdl was just a Supercharged Vogue SE , ====================================
28th Oct 2013 11:08pm |
Thanks Joker - It's a 2005 registered but 2006MY. If that makes a difference? 2006 4.2 SC
28th Oct 2013 11:31pm |
Same as the one I previously had back in 2005 ....... 2005 but a 2006 mdl Supercharged Vogue SE was the highest spec at that time as there wasn't a AB SC then , the AB SC came out in 2007 / 08 mdl ====================================
28th Oct 2013 11:40pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Mine was registered in 2005 as well - 2006MY Supercharged, also listed as 'unbadged autobiography' - mine has the two tone leather which I beleive is the autobiography bit.....hope this helps Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
29th Oct 2013 8:47am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3694 |
29th Oct 2013 10:17am |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
check you have the autobiog plate under the bonnet at the front, should have your AB registered number
29th Oct 2013 10:20am |
