Home > Maintenance & Mods (L322) > EPB Failure and Flashing brake lights :( |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Hi,
31st Oct 2013 12:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
have you tried putting the epb on and off a couple of times? ... - .- -.
31st Oct 2013 12:27pm |
Yes - it doesn't engage (no motor noise, no clonks, no whirrs, nothing). Lights came on while driving, not when parked or anything. Land Rover Addict
31st Oct 2013 12:28pm |
the only thing i can find re the epb is ref to the to the emergency release cable and as yours does not engage then its most probably no help...i suppose you've done the obligatory battery disconnection.. ... - .- -.
31st Oct 2013 12:42pm |
Disabled my DRL's and the EPB worked - then about 30 minutes later failed.
31st Oct 2013 2:19pm |
slightly, try a drop test on the battery to see if you have any dead cells.. ... - .- -.
31st Oct 2013 2:59pm |
It's the original battery from 2006 - so I'm going to take the plunge and order a new one..... Land Rover Addict
31st Oct 2013 3:00pm |
you cant go wrong in a newer battery
31st Oct 2013 3:03pm |
No faults logged on the LCM - only the Parking Brake ECU and the TMC (always there). Land Rover Addict
31st Oct 2013 3:10pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I pretty much always have the TMC antenna fault - but it works fine. |
31st Oct 2013 5:04pm |
TMC isn't the problem and has always registered an antenna fault even though it works Land Rover Addict
31st Oct 2013 5:47pm |
Mine too - although it sometimes required re-tuning |
31st Oct 2013 6:27pm |
Well I am baffled. Had the battery tested, all fine and no need to replace. While there also re-ran fault clearing routine on IID - all cleared. Now I don't get a blank status message on first start (i.e. it doesn't remember which trip option to show, such as TIME, RANGE etc) and it seems very happy. No errors logged for EPB any more and battery seems to be like new Got to love Land Rovers! Land Rover Addict
1st Nov 2013 2:30pm |
