![]() | Home > Technical (L322) > Head light levelling |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Chances are no headlight leveling ecu is fitted to your car according to RAVE as follows.
| Liszton3 Member Since: 27 Feb 2012 Location: UK Posts: 2
Thank you!
Might be worth reading this as well before you go back. From the MOT inspection manual.
| gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37
Somewhat related.... My levelling unit got wet and corroded and killed the k-bus. My Indy has replaced it with a used one from a td6 and can't reprogram it to petrol with his auto logic system.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
AFAIK the mileage is logged in three different ECUs and if you replace any of them, the black dot will appear on your odometer to indicate a discrepancy between the 3 ECUs in mileage. The systems should still work since ECUs can fail and need to be replaced without "stopping the entire vehicle from working". |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Am I missing something here ? Unless your car has adaptive headlights there is no levelling unit to fail, the suspension levelling fulfils that function and you shouldn't have failed the MOT in the first place . 2008 MY Supercharged
Plus one for Axle |
On the earlier cars, in addition to the air suspension self leveling, there was a self leveling system on each xenon headlight which operated thro a small motors and screw-drives controlled by an ecu. This leveling system operated continuously when the car was driven, small adjustments being made as the car drove along.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I totally agree... In 2004 the system was binned and a system that worked was not introduced until 2005/06 on the facelift |
Thanks Craig.
