Home > Technical (L322) > air supensioninactive prob only have jeep2weeks
Page 4 of 6 <123456>
hse 2004
Ireland 2004 Range Rover HSE Td6 Baltic Blue
air suspension inactive no lights on control button
Can any 1 help air suspension inactive message with no lights on control.I have tried disconnecting battery and connecting with wheel left 2 right clears abs sect but not inactive message or lights on Manuel button.have had it on computer reset twice worked fine to two days each time and then inactive message appears tuning of lights on Manuel button.have done a real test compesser running but no lights on and message still on.pulled fuses and no joy.can any 1 help Big Cry what could the reason be
Post #222491 12th Nov 2013 9:14pm
Martin
Site Admin
What did the fault codes say or did you just clear them without reading?
Post #222493 12th Nov 2013 9:16pm
hse 2004
Code reader Says no fault soul this b down 2 a loose senor connection if so o u no were
Post #222502 12th Nov 2013 9:59pm
whats the condition of and how old is the battery? if around 3/4 years old i would put a new one on.. ... - .- -.
Post #222572 13th Nov 2013 8:15am
Question Question Question If the lights are out there will be a code... Take it to someone that knows what they are doing before your sat on the side of the road on your bumpstops scratching your head... Whistle
Post #222576 13th Nov 2013 8:28am
Martin
Site Admin
^^ agreed. And threads merged again...
Post #222578 13th Nov 2013 8:30am
Prepare for a new thread
'air supensioninactive prob only have jeep3weeks' Laughing Laughing Laughing
Post #222583 13th Nov 2013 8:40am
hse2004 obviously has a problem with spelling and is in a bit of a fix so it would be appropriate as conscientious forum members to try and help him.. ... - .- -.
Post #222587 13th Nov 2013 8:43am
Hear hear... I would guess maybe even English is not his first language...
Post #222591 13th Nov 2013 8:48am
But i bet his English is better than most of your F, D, SP, NL etc etc etc (im sure you all get the point) Whistle
Post #222594 13th Nov 2013 8:50am
hse 2004
If I disconnect the battery and touch positive lead 2 negative .could this work or cause a prob
Post #222750 13th Nov 2013 9:27pm
It's ok... It will not cause a problem.... As long as the battery is definitely disconnected... Thumbs Up Previously..
Post #222752 13th Nov 2013 9:32pm
hse 2004
Will try 2maro and c if it clears it.will report back.thanx
Post #222756 13th Nov 2013 9:40pm
It won't clear the fault
Post #222776 13th Nov 2013 10:45pm
hse 2004
Any tips
Post #222778 13th Nov 2013 10:51pm
