Home > Technical (L322) > Whine noise on take off and slowing down.
Googsy
Just noticed a new sound this morning sounds like a whine but disappears as car goes faster. I have tested car in neutral and revved engine and sound is audible at low revs then disappears until winding down so noise is not drive train related. I have no noticeable decrease in performance or increase in smoke. Thinking it might be a split turbo hose which I know can be common. Anyone confirm that's what it might be or maybe suggest alternatives? also excuse my lack of tech knowledge but are turbo hoses on tdv8 the 2 pipes that go into radiator? can't check as pitch dark outside.
Thanks
Conor Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #221270 6th Nov 2013 9:42pm
I have noticed the same on my disco, sounds like a low whistle/someone blowing over the top of a bottle. Moderate load at about 1500rpm.
Came to the same conclusion as you, that it is a leak in the turbo pipe somewhere. Haven't had chance to investigate yet. There is nothing that can't be fixed with a hammer😜😜
Post #221296 6th Nov 2013 10:18pm
Googsy
Yes not a bad noise or loud but noticeable. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221297 6th Nov 2013 10:20pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Could be bearing on the alternator or one of the aux belt tensioners 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #221306 6th Nov 2013 10:40pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
A split of any size in the turbo pipes to intercooler would def result in loss of power I would guess tensioner/pumps etc Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #221352 7th Nov 2013 12:06am
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
I just had this problem. I let my local dealer have a listen to make sure I wasn't hearing things and after they inspected the engine bay with the engine running they found that one of the turbo hoses was torn as shown in the first photo. Cost me 110EUR for a new one because it comes in a three-part set (part no. LRPNH500460) shown in the second photo. Working fine now, though Thumbs Up
 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #270031 10th Jul 2014 2:16am
FrankRizzo
Hmmm, spoke too soon. After a long trip to the Alps and back the noise has returned, if not quite as loud as before... Neutral 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #273548 30th Jul 2014 1:25am
Re: Whine noise on take off and slowing down.
Thanks
Conor
Girlfriend/wife Conner Whistle Whistle Whistle
Post #273564 30th Jul 2014 9:00am
