![]() | Home > Technical (L322) > td6 Gearbox Replacement |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
The E53 and early L322 are very closely related and use the same engine/transmissions combinations i.e. 4.4l uses the ZF 5HP24 and the 3.0l uses the GM 5L40-E. The back ends of the transmissions are slightly different as the X5 uses the NV125 (single-speed) transfer box and the Range Rover the NV225 (two-speed).
