![]() | Home > Technical (L322) > 2003 Vogue Drivers door wont lock/unlock with key? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Use search, I repaired mine a year or two ago |
Plant Member Since: 01 Oct 2013 Location: Wirral Posts: 38 ![]() ![]() ![]() |
Tried the search but keywords are quite specific |
Odd that coz when I searched a few threads came up that I replied to |
Might be an idea to put this into Wiki |
Thank you, that was much more helpful |
Well if you're not very mechanically minded why not leave it to the professionals
Because I believe in trying to do things myself, I just need to be armed with methodical instructions!. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Plant, all for you doing jobs yourself my friend... But sometimes there are jobs to leave to the professionals... I personally think this is one of them... It's quite tricky & if it goes wrong! You could be seriously in the mire... |
Thanks Craig, but I've fixed the key locking issue now |
Ive had the panel off and the cable seems to be in tact and in place. The handle is rather stiff though, I have to put my thumb on the lock to get enough force/leverage to pull the handle open. I think it may be prudent to order a spare cable in case of emergency!! |
Try opening the door, clicking the latch across with the door open (using a screwdriver) then pull the handle and see if it releases easily... If it does, close the door slowly and see if the striker on the pillar is pushing the door up or down or too far in? Can also make the door hard to open... (kind of initial jolt as the latch releases) if so, then it needs the torx bolts loosening and the striker plate aligning |
Cheers Craig, will give that a try next weekend |
Unnecessary quote removed
Worth a try |
