![]() | Home > Maintenance & Mods (L322) > Wing Mirror Upgrade |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
Not sure if it can be done, but CTC may know.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
05-09 mirrors will fit (plug & play) to the 02-05 cars but the mirrors wont powerfold in correctly without the 05> window switch pack (different software?)
| jimmy2508 Member Since: 08 Nov 2013 Location: East Sussex Posts: 8
Thanks for the quick response guys.
The switches you press in the top of the door panel are the switch pack... Has a built in ECU so needs to be changed to an 05> one (which looks identical but has a different part no) |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102
as Craig said, are plun and play, (up my09) but not close properly, without the switch pack
