Home > Maintenance & Mods (L322) > Rear light problem
Squaresausage
Scotland 2003 Range Rover Westminster 4.4 V8 Baltic Blue
Rear light problem
I've got a problem with my rear near side light. The lamp with the double filament is working but the lamp is very dull when compared to the other lamps and I also get a warning on the dash. I have cleaned all the contacts and checked the wiring.
Any ideas? I also have bought a recon LCM to be fitted as I often get spurious warnings of lamp defects.
Cheers What has fallen off today:-)
Post #222926 14th Nov 2013 5:12pm
i would have said a bad earth problem....have you changed the bulb... ... - .- -.
Post #222927 14th Nov 2013 5:23pm
Googsy
As Stan says trying swapping bulbs over and see if symptom arises on other light unit. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #222929 14th Nov 2013 5:24pm
Squaresausage
Yes changed the lamps, any idea where the earthing point is? The strange thing is the lamp starts bright then dulls down. What has fallen off today:-)
Post #222936 14th Nov 2013 5:44pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Sounds like a bad connection - Try checking with a voltmeter
Post #222939 14th Nov 2013 5:54pm
It's possible you have an earth fault in the bulb holder or adjacent mounting.
It sounds as thought one filament is earthing thro the other filament and its earth due to a problem with the first's earth, hence the bulb appears dim.
Post #223016 14th Nov 2013 9:50pm
Squaresausage
I've changed the lamp holder but the problem is there, going to see if I can get a wiring loom changed as the earth points seem ok. Got a good diagram from V8 saint on another forum. What has fallen off today:-)
Post #223770 18th Nov 2013 10:16pm
