Home > Off Topic > courier for big items
johnboyairey
couriers
i have used many online parcel couriers, i have shifted alloy/tyre sets around the uk, with them, you send each wheel/tyre as a separate item, and send 4 together, giving you a slight discount. I sent a set of widish p38 rangy wheels/tyres for about £30 the set. you have to wrap them, but only really need a small circle or cardboard and a few bin bags accross the faces. when you search for say parcel2go etc, and input the dimensions, you dont have to be 'exact' so squeeze them down a tad, and you get the magic £6 a parcel. the guys never meusure! limit is 30kg and around 60cm diameter. then it goes up to about 17 per wheel.
a pallet is a pallet, whether its full or empty, its arond £75 but a godsend to move an engine, or interior. they collect with a forklift. all this saves us a day driving there and back, and the fuel!
p.s you track the parcels online.
Post #223296 15th Nov 2013 11:36pm
note that if you are buying just wheel rims make sure the seller has wrapped them up properly cos if they are dropped they will dent very easily... ... - .- -.
Post #223336 16th Nov 2013 10:23am
B3EEE
2005 Range Rover Supercharged 4.2 SC V8 Tangiers Orange
£45-£50 for half a pallet at www.p4d.co.uk. use them regularly for standard parcels too.  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #223344 16th Nov 2013 12:49pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
am going for the wheels and tyres and phil said that he will wrap them individually so should be ok i reckon.....
Post #223557 17th Nov 2013 8:26pm
