![]() | Home > Maintenance & Mods (L322) > Alignment done weekly |
After my saga with seized rear track arm brought it back to have alignment redone at weekend. Steering wheel is now off to the right pity as car drives quite well but can't focus on enjoying it as the steering wheel really |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
its got to be done again Conner cos although it drives ok that off set steering wheel will bite you every time you get in to drive it.. ... - .- -.
Aside from that, if the steering angle sensor is not zeroed, sooner or later you'll pop a fault. Many modern cars have steering angle sensors for the stability control systems - not just RRs. This does not necessarily speak for the alignment shop... |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi mate, im in cheshire too and need a wheel alignment done. Where did you take yours for £60?
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
60 quid isn't that expensive - let me know where as well please. I can easily get to Cheshire particularly if the alignment place is conveniently near a pub that I will be taking SWMBO out to lunch at |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Mine went to Jeffreys in Warrington. They checked the whole lot and quoted £120 as 'worse case' scenario but when they called to say it was ready it was a shade under £60 with VAT.
is it this company?
I take it once wheel is straight or very near to I can reset steering wheel angle sensor using iid tool and all should be ok? Present :2008 TDV8 HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Does anyone know anyone in the derby area who can do a 4 wheel align?
Yep makes you question the entire alignment mine back on Saturday. Im armed with iid tool as it will display steering wheel angle using live values |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
£60 |
£160 is not unheard of PD |
Tell me about it 2 hours with a grinder two Russian dudes and 40 Marlboro |
