![]() | Home > Maintenance & Mods (L322) > Alignment done weekly |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I've been charged as much as £200 in Aberdeen for a 4 wheel alignment on a Touareg. Cracking job but typical of local Aberdeen pricing for most things. 4.4 TDV8 Vogue Baltic Blue MY11 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Protyre - 50 quid. make sure whoever does it has the right equipment as it requires special 4 x 4 I believe. |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Had mine done at a tyre place once for £40 took about 20 minutes and cost me 2 front tyres within about 2 months as it took the outer edge off them both, ended up getting it done at the dealers for £160 and it took 2 hours and recieved a full print out of all the measured angles against the specs. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
It's a specialist job.... The guy doing it has to know the exact spec and tolerances of what he needs to achieve. I did it myself once with some borrowed mirrors and equipment.
Right 3rd trip to garage on Saturday car drives straight but wheel is at 2 o'clock position. On first name terms with the manager at this point. I show operator where wheel is pointing when driving straight and he sets up alignment machine. He gives me a call for me to set car into tight tolerance mode. After ten minutes he gives the thumbs up the cars ready. He asks me to take car for a drive and return if still off. I go for a drive and discover wheel is now at 1 o clock position. I go back and they tell me they are too busy and I will have to wait |
