Home > Technical (L322) > 2010 MY- where is the FBH located
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Im struggeling to locate my FBH, apparently its supposed to be in the engine room some where Shocked In the climate menu i find where I can set the timer, but the manual options are "greyed" out.
I bought the vehicle second hand and I have a copy of the vehicle specs (based upon the VIN#) where the "auxiliary heater" is included. I also have a FOB for the park heater, but when i switch it on, its only blowing cool air- even below freezing temperatures.
Are there by any chance a software drop out that has resulted in that the manual options are not available Question
Any idea what and where to look for finding the FBH (if it is there) ? Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #224967 24th Nov 2013 5:54pm
The fbh is fitted on under the wing on the right hand side as you look at the car from the front. Kind of behind the side vent area.
It is not visible unless you remove the wheel arch liner though you may he able to see the exhaust from under the car. Small pipe about 25-30mm in diameter.
It is probably not working, most arent at this time of year especially if they havent been used for a while! There is nothing that can't be fixed with a hammer😜😜
Post #224993 24th Nov 2013 8:56pm
Re: 2010 MY- where is the FBH located
You mean it's on the left hand side of the car? Whistle
Post #224997 24th Nov 2013 9:18pm
Confused Rolling Eyes
In the uk its on the passenger side! There is nothing that can't be fixed with a hammer😜😜
Post #225002 24th Nov 2013 9:37pm
From the front are you left or right handed? Smile
Post #225005 24th Nov 2013 9:49pm
Sitting looking out from the drivers seat........with the wheel infront of me..........
Its on the left......... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #225008 24th Nov 2013 10:04pm
ksskaret
Thank you for your replies Smile I also went into the TOPIx (made a 1 week subscription) and found all my data with reference to my VIN # and it confirmed that I have a park heater Very Happy
And northernmonkeyjones is probably right that it just doesn't work - It will be serviced later this week at my dealer so I expect them to rectify it Smile
And as northernmonkeyjones says, its on the LH side (both for RHD and LHD) and you got to remove the wheel arch liner to find it.
Thanks again Exclamation
Simon Range Rover TdV8 Autobiography MY2010
Post #225035 24th Nov 2013 11:59pm
What about when you're looking from the front?
Post #225046 25th Nov 2013 7:44am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Mine had the same issue but I cleared the fault codes and it fires up nice and toasty again now Cool
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #225059 25th Nov 2013 10:05am
SteveMFr
Site Sponsor
Really? Did they change that? Earlier L322s had the FBH on the passenger side - i.e. RH for a LHD vehicle. So for the 2010 > it was left on the LH side for both versions?
Learn something new every day...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #225134 25th Nov 2013 3:54pm
ksskaret
Steve, will according to TOPIx LR workshop manual it is the same side for the 2010MY. But by all means I could check again Smile Range Rover TdV8 Autobiography MY2010
Post #225149 25th Nov 2013 4:53pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I have my car in because I encountered exactly the same problem, FBH is working (the fans are blowing) but no hot air is coming out. Dealer says it needs a new FBH so a new system has been ordered.
Post #225153 25th Nov 2013 5:01pm
They seem to treat is a whole part, and dont break it down into components, so if its not working a MD will order and fit a new one.
For older out of warranty cars they can be serviced or repaired, new ecu's, injectors and water pumps are available separately. There is nothing that can't be fixed with a hammer😜😜
Post #225160 25th Nov 2013 5:40pm
SteveMFr
Site Sponsor
I don't know how it is in the rest of Europe, but in Germany most Bosch service centers are also specialized in FBH. They are very serviceable - and quite simple. In Germany, there are numerous additional FBH specialists in every larger town as well. But then, Germany is the home of the FBH so it might be different in other countries...
Treating "it" as a unit is a typical big manufacturer thing. LR used to sell only replacement valve blocks for the P38 EAS for ~800. They were easily repairable with O-rings from any hydraulic supply shop...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #225226 25th Nov 2013 10:33pm
I agree, having seen how they are put together there really isn't much too them! There is nothing that can't be fixed with a hammer😜😜
Post #225228 25th Nov 2013 10:40pm
