Home > Technical (L322) > vibration on braking
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
hi all, I consider myself to be a pretty clued up guy as I am a mechanical engineer, but I am confused today. earlier in the year and only about 3000miles ago, I changed the front discs and pads front and rear on the FFRR.
over the past few weeks I have had a vibration on braking above 50mph and it has got steadily worse. I presumed that I had a warped disc which I am annoyed about, but understand things happen.
So I bought a new set of discs yesterday and went to fit them this morning. Well after huffing and puffing for about 20 mins and using all the tools and tricks at my disposal at home, I couldn't crack the caliper bolts, so decided to leave it and do the job at work. before I put the wheels back on I checked the disc securing/locating screws and the near side one was about half a turn loose. I tightened it up with the allen key and put the wheel back on. then went for a drive for a few miles to check everything and no matter how fast I drove or how hard I braked, not so much as a vibration!!
Surely the little allen bolt didn't stop the vibrations as the wheel studs pull everything up even if the allen bolt wasn't fitted.
has anyone got any ideas as to what is going on???
Any help advice gratefully accepted even if it does mean me looking like a plonker for missing something obvious. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #226351 1st Dec 2013 3:25pm
just wondering if taking the wheels off/on resulted in the vibration disappearing, maybe they were not seated properly?... ... - .- -.
Post #226353 1st Dec 2013 3:33pm
I think you might have been lucky just by putting the wheel on in a different position.
I never tighten the allen bolts anyway then at least I can get them out when I want to.
Post #226354 1st Dec 2013 3:40pm
stu
i haven't got a clue what is going on!! my mate runs a garage and he balanced the wheels for me last week, just for somewhere to start. the allen bolts are only just nipped up, not over tight. as you say maybe just taking the wheel off and replacing in a different position has done the trick. I will know for sure after my trip to work tomorrow, nearly 80 miles round trip, that should be far enough to let me know if anything is wrong.
all in all it's a mystery to me, just hope my friendly L/R dealer will take the discs back if all is well!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #226400 1st Dec 2013 7:41pm
stu
just to ask another question with regards to my vibration. I noticed over the last couple of days that it seems to be doing it again, although no way near as violent as before, more of an irritation than anything. Could tyres be an issue in this situation?
Although my tyres are perfectly legal there is probably just by looking, only 3.5 to 4 mm of tread depth left. Could that upset things in any way?
just clutching at anything now due to it beginning to get under my skin a bit. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #227665 8th Dec 2013 4:54pm
It could be a lower control arm on its way out... Previously..
Post #227666 8th Dec 2013 5:31pm
stu
thanks for that worth having a look at. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #227672 8th Dec 2013 7:08pm
