![]() | Home > Technical (L322) > Wind Noise Drivers Side 50mph + |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
had a similar issue in october .
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Can also be the rubber strip in the rain channel. Mine came away at the front and was like a ski tip at speed so caused a drone noise. Fixed it down and no more noise! |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
@ goldsax, will give the pillar trim a good press to see if its that.
Sorry wasn't clear! Can't take pictures as it was my prevIous rr and my present one has roof rails so it can't be seen.
Where about on the A pillar is the noise coming from/ does is sound like a window is partially open?
It sounds like it comes from the front corner, there's no draft between door and A pillar from inside the car so perhaps it a whistle from air getting under the A pillar trim and not being able to go anywhere?
There was no draft with ours. |
