Home > Technical (L322) > Timed Climate V8 SC |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Are you talking about the heating or cooling aspect? Most Petrol RRs dont have an FBH unless spec'd in the build. However it is possible to cool the car via the aircon I believe (may be wrong.. am sure someone will correct me.) |
2nd Dec 2013 10:26pm |
Some did have fbh fitted though i think it was an option rather than standard fit. Tricky to visually
2nd Dec 2013 10:33pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
I have only used mine via remote, on frosty mornings to get worst off the windscreen.
2nd Dec 2013 11:10pm |
Open the car up and turn the nav screen on but don't put you key in , go to timed climate in the set-up screen and turn the FBH on to manual , it should now start to run so leave it for ten minutes and see how warm the cabin gets .
3rd Dec 2013 1:34am |
