![]() | Home > Maintenance & Mods (L322) > tow bar |
If you use it a lot then leave it in, if you only use it occasionally then remove it as it has a habit of removing shin skin |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Mine stays in place most of the time . Fitted with a locking pin so no low life can steal it. I've even fitted it with a step so I can reach all the way in
Just refitted mine on today with a nice big bolt and nut, the daft quick release pins are crap... |
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 ![]() ![]() ![]() |
i leave mine in as i've lost the bung, on my previous one i had no bung and when i went to fit the receiver, it wouldn't go in. The inside of the box iron had stared to rust, only surface rust, but enough to cause it not to fit in properly, had to sand and then lube it, then it all worked. Hope it helps. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Mines bolted on. What's all this about a quick release pin? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Mines in. if someone hits you up the ar |
