![]() | Home > Maintenance & Mods (L322) > Melting cornering (headlight) or design flaw? |
Presently going through a careful and considered process of 'upgrading' headlight bulbs within the adaptive cornering headlight unit (pictured). This morning, my attention was draw to the driver's sidelight and cornering unit bulb housing where the outer rim of the bezel looked just a little mis shapen to the point that I started to query whether a 2 day installed cornering LED bulb could have started to melt the unit.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Same here , on both of mine . LED are cooler I thought ? Alcohol and eBay is never a good mix
I might have a spare insert to fit as I have spare headlight not sure if both sides are uniform for that lens though |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
can you do a close up pic ryan?
BILLTU Member Since: 23 Jan 2013 Location: Glos Posts: 73 ![]() ![]() ![]() |
Think this has been mentioned in another thread. Somebody had got stuck at a junction for a few minutes. Cornering light was on due to wheels being turned. Housing melted. I'll see if I can find the original post. 2016 3.0 Vogue
if that is the case then its a valid reason to stick leds/crees in place of the halogens.. ... - .- -.
Which I have done, but the damage has already been done |
Thanks for all of the replies.
ouch...
Well I've just checked the Halogen cornering bulb that was fitted previously to that headlight (or static bending lamp as the owners handbook calls it).
thats a OE fitment bulb... |
Okay, I've located at least 2 historic threads that cover the cornering part of the headlight housing melting. The first thread was by Bellini and see the pictures of how his headlights had really melted which confirms that ours is 'nothing' and might even be a slight design flaw as opposed to a melt.
This is a very common issue and has been since the facelift in 2005... 9 out of 10 customers cars have melted plastic above the cornering lights...
