![]() | Home > Technical (L322) > Gearbox Help needed |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1040 ![]() ![]() |
Knowing the issues that repeatedly seem to be emerging with the ZF 6HP26 Mechatronic unit – and in particular the proportional solenoids - we should consider the possibility that the adaptions have been compensating for a fault with one (or more) of the solenoids such that, when they are zeroed, the full extent of the fault is brought to light. If that's the case, the problem is with the solenoid(s) not the diagnostic kit.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
^^^^ Agreed. I accept that it's not the diagnostics tool that's caused this but whilst the gearbox was compensating it worked and this has just caused a whole heap of trouble.
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
I do agree with Phil his knowledge is unbelievable on these boxes and I now understand that there must of been a fault before and as Phil says the ecu adaptations where masking it. It may of lasted a week or a year if I hadn't of messed it always happens at the worst time though. The difference between theory and reality is that in theory it will work. |
How many miles has it done, Dave?
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Just what I was trying to say. |
It's done 126,000 I was going to do some ringing round today but havnt feeling a but deflated with the car now but it is the only problem I've had and I suppose it's piece of mind to know the gearbox is ok when it's been done. But I've parked it up on the drive and will deal with it after Christmas as no one is going to be able to look at untill then anyway will Keep you all up to date.
Also consider going the auction route.
Phil, is the ZF 6HP26 not as bullet proof as first thought then? Have you seen many of these? Any observations on the cause? 2006 4.2 SC 2019 Renault Zoe Dynamique Nav ![]() |
I understand what your saying Scot. I'm going to stick with her I have not had it long and it took a while to find apart from the gearbox I have a load of recipts of work that's been carried out its only had one owner and is mint. I couldn't believe it when I found her it has a FBH too with remote and it works |
The 6HP26 has been in production for thirteen years now and I’ve heard of virtually no issues relating to either mechanical or hydraulic faults with this transmission, which is amazing. The only problems I’ve read about or come across seem to relate to either software (adaption) or solenoid issues, neither of which requires the transmission to be removed from the vehicle to fix. Automatic transmission repair shops (in the UK, at least) believe it isn’t economic to start stripping down valve block assemblies so they just replace the whole unit. In the case of the 6HP26, ZF have encouraged this by not making the individual parts available anyway (and, until recently, that included the solenoids), whereas on previous transmissions like the 5HP24 all the blocks, spools and springs were available separately. Also on the 6-speed, unusually the individual solenoids are set up at the factory to match the required pressure and flow characteristics for a given valve block as the transmission ECU is an integrated part of the valve block assembly
hence ZF claim that the Mechatronic unit should only be replaced as a complete unit. However, from the previous experience of others, I know that after resetting the adaptions following solenoid replacement the ECU successfully relearns the settings for the new solenoids very quickly. In summary, I think that the 6HP26 is pretty bullet-proof and that any issues that do occur are generally pretty simple & relatively inexpensive to fix. Certainly more reliable than the 5HP24 in any case. I won’t even compare it to the 5L40-E which, as we all know, is actually made from cream cheese and cotton wool and is unlikely to last beyond 80k miles in a Range Rover. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Based on my experience with the 3-4 shift fault, the resolution was "just replacing the coils or proportional solenoids". It is a relatively cheap solution (compared to a full gearbox replacement).
Very useful feedback. I read it (and maybe I've misinterpreted it) that Av_dave is planning to replace the whole 'box. You are saying he may not need to do that? 2006 4.2 SC
Hi Skot, absolutely, first just replace the solenoids and do the fluid and filter as an option. I suspect that the gearbox is fine it is just the solenoids that seem to be causing the issue.
Im not so sure about just replacing this and that within the mechatronic unit at this milage, mine had its mechatronic sent to a mechatronic recon centre in Luton, repaired and tested etc, when it came back and was refitted it was no better !.
