Home > In Car Electronics (L322) > Wiring in a hidden lighter....how to?
Ok, I've bought a dash cam and it comes with a wire with a small usb plug for the camera end and a big thing for shoving in a lighter socket on the other end.
I'd like to have the wire 'disappear' somewhere round the headling into the depths of the dash and become live when the ignition is turned on.
I can get a lighter socket from Swiss Maplins but I'm not sure where I should wire it in. I have seen a thread on it but can't find it. Please would some nice kind someone point me to the thread or advise? You can have some of my Stilton - and no, that's not a sexual euphamism.
Post #229177 14th Dec 2013 9:10pm
Buy one of these below and fit a 5A fuse in it.
Connect your lighter socket centre pin to the above adapter with a length of 5A cable.
Connect your lighter socket side pin to a suitable earth bolt with a length of 5A cable
Plug piggy back connector into unused Fuse 7 on the glovebox fuseboard.
Locate lighter socket above access panel above feet area in passenger footwell. (RHD) May be other side of car for LHD.
Insert plug on cable from camera into lighter socket and run cable to camera.
Switch on ignition and camera should work. Thumbs Up
http://www.ebay.co.uk/itm/Blade-Fuse-Piggy...3381a0cf7f
Post #229181 14th Dec 2013 9:34pm
Thanks nicedayforit. I had a suspician it would be you who came in first.
I had no idea there's a fuseboard in the glovebox.
Sorry, I've finished all the Stilton.
Have some rather nice orange sorbet if you're interested?
Post #229184 14th Dec 2013 9:54pm
Should have said "fuseboard below glovebox" assuming it is the same on a LHD.
Orange sorbet would be fine. Thumbs Up Smile
Post #229185 14th Dec 2013 10:01pm
Sorry, I've finished all the sorbet. Embarassed
Post #229186 14th Dec 2013 10:03pm
Here's how I ran the cable for mine.
I've since moved the camera to be lower & central.
I cut the cable on the end to remove the lighter socket, bolted the -ve to the metal frame under the glove box & found an unused fuse that was +12v only when the ignition was on - empty fuse slot
I then soldered the +ve wire to win in-line fide and crimpled the other end to a spade terminal & cut it down to be the same size as a a blade fuse and pushed into the empty fuse holder.
I hope that makes sense.
Fuse box is behind the glove box.
No stilton or sorbet were needed for my installation Thumbs Up
Post #229200 14th Dec 2013 10:48pm
David, does yours have vanity mirror lights fitted? They are near the camera site and the 12v power is ignition fed Thumbs Up
Post #229202 14th Dec 2013 10:55pm
These?
Post #229211 14th Dec 2013 11:12pm
No No, the illuminated vanity mirrors under the sunvisors sir Bow down
Post #229215 14th Dec 2013 11:21pm
These?
Post #229217 14th Dec 2013 11:33pm
Yes sir... These lights are ignition fed Thumbs Up
Post #229220 14th Dec 2013 11:42pm
Ok, thanks for the tip. Thumbs Up
I'll have a look in the morning.
Post #229224 14th Dec 2013 11:44pm
