Home > Maintenance & Mods (L322) > tow bar
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
tow bar
i know have all the various bits to put it all together.... quick q though.... do people put the receiver in and leave it there ie with the holding pin in or do people take it out until they are using it.... strikes me that its a bit of a faf to keep doing that?
Post #227784 9th Dec 2013 1:23pm
If you use it a lot then leave it in, if you only use it occasionally then remove it as it has a habit of removing shin skin
Post #227788 9th Dec 2013 1:57pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Mine stays in place most of the time . Fitted with a locking pin so no low life can steal it. I've even fitted it with a step so I can reach all the way in
Gary
Post #227789 9th Dec 2013 1:59pm
Just refitted mine on today with a nice big bolt and nut, the daft quick release pins are crap...
Post #227801 9th Dec 2013 3:40pm
tobylo
Ireland 2008 Range Rover Vogue SE TDV8 Stornoway Grey
i leave mine in as i've lost the bung, on my previous one i had no bung and when i went to fit the receiver, it wouldn't go in. The inside of the box iron had stared to rust, only surface rust, but enough to cause it not to fit in properly, had to sand and then lube it, then it all worked. Hope it helps.
Post #230806 22nd Dec 2013 4:03pm
Andy
Mines bolted on. What's all this about a quick release pin?
Post #230808 22nd Dec 2013 4:15pm
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
Mines in. if someone hits you up the ar Censored there car is aright off Shocked 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #230811 22nd Dec 2013 4:17pm
