Home > In Car Electronics (L322) > sat nav urgrade disc
Page 2 of 4 <1234>
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
is there a way to tell which year dvd sat disc you have in?
2011/2012 WE is £169 from navteq but not sure which year i have got
Post #229755 17th Dec 2013 2:03pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
when I've popped mine out before now I noticed it has the year on it. Perhaps yours may
Post #229771 17th Dec 2013 3:58pm
T24RES
Yes you may change the country. But it defaults back to France, and for £3.99 i expected better Wink
Post #229792 17th Dec 2013 4:44pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I can only get the original LR discs to work in mine, and was told by an Indy DVD repair/recon company that the copies
damage the laser optic thingy (sorry not very technical I know)
The DVD units are about £300 to service recon or on the bay about the same for a second hand unit Rolling Eyes
So £169 for genuine navteq disc don't seem so bad imo
Post #229921 18th Dec 2013 12:33am
DMRR
DVD's break lasers? Er....<cough>
Someone is telling porkies - what can happen is you use cheap dual layer DVD's and they warp. Just make multiple backups or proper (TDK etc not Tesco) DVD's. Also backup at the lowest speed possible. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #229934 18th Dec 2013 12:59am
zetjester
I have tried a few copies and only the original disc will read! Sad
So are you saying if I copy the copy with a good quality disc it should work, either that or maybe it is my DVD drive ??
thanks Thumbs Up
Post #229940 18th Dec 2013 1:06am
DMRR
Yep - slowest speed possible and good quality backup discs Wink
If you are using Windows - Nero,alcohol or imageburn are the preferred tools.
If linux then pretty any of them work Whistle Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #229945 18th Dec 2013 1:14am
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Hi guys I'm new to this RR scene and was wondering will a newer map DVD work in my 2005 RR, also where is the best place to locate said item.
Many thanks
Paul 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #230649 21st Dec 2013 2:15pm
tobylo
Ireland 2008 Range Rover Vogue SE TDV8 Stornoway Grey
@ Paul_H, i have 2 original discs, 2005 and 2007/2008 that i no longer need. Send me a PM and i'll send you on the details. They work in the Denso units, if you have a touch screen sat nag they will work.
Post #230809 22nd Dec 2013 4:15pm
tobylo
Sat nag !!! Rolling with laughter So true Wink
Post #230810 22nd Dec 2013 4:16pm
n1cktdv8
KurtVerbose wrote:
There you go Stan.
Surely these are from the same supplier as the RR puddle lights Rolling with laughter Is this where I put the car details and a bit about myself ?........
Post #230815 22nd Dec 2013 4:26pm
Here in Australia if you need a new disc you are screwed Sad The map discs are produced by a set up called Where is and now that all Land rover sat nav's are HDD apart from the Freelander2 Land Rover Australia who do not do customer service at all will not authorise discs to be made :bulb:
Freelander disc won't work in FullFats Disco 3's or Sports and I have been quoted $1000 for a 2008 disc off a stealer.
Land Rover Australias attitude to its customers is staggering , once we have your money you can royally Censored off. Banging Head 2008 MY Supercharged
Post #230941 23rd Dec 2013 3:39am
RR2008HSE
Banging Head and Censored is right. The newest discs we can get is the "2011-2012". Considering what they charge for the sat nav, the fact they won't issue update discs is COMPLETELY UNACCEPTABLE!
I hope someone draws this to the attention of the JLR Customer Service guy. Whistle
Post #230945 23rd Dec 2013 5:05am
It won't make any difference. If you still have CD navigation you won't find newer maps than 2003.
Post #230951 23rd Dec 2013 9:46am
pm sent David.. ... - .- -.
Post #230955 23rd Dec 2013 9:55am
Page 2 of 4 <1234>
