![]() | Home > Technical (L322) > Car won't start :( |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
Sounds like a duff battery Rowly.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Agreed. Batteries have a habit of failing with little or no warning. Check it with jump leads, if it starts: new batt! |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
I concur with with RRUK.
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
I too concur
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Saxtons should cover a battery anyway shouldn't they?
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Yeah, definitely sounds like a battery Rowly - have you tried jump starting? Ensure you use a decent thick set of leads also: and as suggested above, switch everything else off. However, run a voltmeter across the battery when the engine's running to check your alternator output - just to be sure. |
topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 83 ![]() |
Thanks so much for all the comments lads, much much appreciated.
My Dad's has been at the Dealer for over a week with a flat battery issue.
Get Saxtons to replace the Battery anyway as it SHOULD NOT discharge for the reasons you set out. In my cars I could have the Pre-Heating on for 30 minutes with full fan on in minus 10 degress and the Battery was still full of life "Every Time" and thats the key. You MUST be able to rely on your battery 100% of the time not 99%.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 268 ![]() ![]() |
Once your battery fails, it doesn't matter how much you charge it, it will discharge very quickly from then on. Get a new one. 2021 3.0 P400 Vogue
