Home > Technical (L322) > Windshield wiper arm removal
funnyguy1
United States
Does anyone know how to remove the windshield wipers on a 2011?? I have to replace the piece they mount thru that runs
along the windshield. Thx! Mike
Post #231182 24th Dec 2013 2:02am
To remove the arm you will need a small 2 arm puller, lift up the cover (no 4 in lower image), remove the nut and washer (no 5 & 6 in lower image) and put the puller onto the back of the arm and tighten the puller onto the spindle then gently tighten the puller bolt. The arm will pop off if done properly
Post #231184 24th Dec 2013 2:15am
funnyguy1
United States
Thank you 47p2, what is a "small 2 arm puller"?? Mike
Post #231194 24th Dec 2013 5:34am
most times you can jiggle the arm off with a screwdriver.. ... - .- -.
Post #231206 24th Dec 2013 9:26am
comports
Remember to put the new arm on at the right angle to the screen or you will get that knock sound as it starts or stops it's wipe action. (apparently 86 degrees against the window when parked - thanks IT Guy)
Not sure how you'd measure 86 degrees but I did mine by eye roughly and it fixed the noise)
For pullers - something like this ( linky )as there is not much room for a screwdriver and not a lot of leverage space as it is right next to the scuttle/screen Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #231217 24th Dec 2013 10:12am
mine came off easily with a screwdriver but the angle adjuster plate was stuck fast.. ... - .- -.
Post #231221 24th Dec 2013 10:25am
comports
Sorry Stan - you are correct - it was the adjuster plate that is hard to shift without pullers. And it's this that needs to be moved if the angle is wrong..! Bow down Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #231224 24th Dec 2013 10:28am
Thumbs Up ... - .- -.
Post #231226 24th Dec 2013 10:29am
paneldamage
The angled/grooved seating plate is pressed on to the spindle, it needs a puller to get it off. You don't need to remove it to change the angle of the arm though.
A word of warning though, the seating plate is a very tight fit on the spindle, and will be a sod to get off. IIRC you are supposed to fit new seats onto the spindles when you replace them. On my 2007, I gave up trying to get them off, even after soaking them with penetrating oil etc, and using a good quality puller, I was risking damaging the spindle.
Post #231383 25th Dec 2013 5:15pm
adigorn
There might be no seating plate on 11my
not sure bout us market Question
Post #231384 25th Dec 2013 5:25pm
drakes
I had to cut off my seating plates as I could not shift them with a puller. The later wiper arms do not seem to have the seating plates. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #231473 26th Dec 2013 2:21pm
