Home > Technical (L322) > Non starter 4.4 v8
Saltyfish
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Non starter 4.4 v8
Went to start my 4.4v8 early this morning after a day of it being stood up. Turned over but would not start (it was fine 24hrs ago). I have checked fuel pump and that is fine i also checked fuel is being delivered at fuel rail and thats fine.
Now added to the problem is it now nolonger has any dash lights and the steering does not adjust when the key is inserted, no radio either although the seats and steering will adjust manually. The key can be inserted and turned all the way but there seems to be no power available.
I have a fully charged battery and have checked all visible fuses.
HELP!!!!!! 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
99 Discovery ES 4.0LPG
96 Discovery ES 3.9LPG.
Post #231994 30th Dec 2013 3:28pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
What a pain, have you disconnected the battery and reconnected? 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #232004 30th Dec 2013 4:30pm
Saltyfish
Yes have tried that, have also now checked fuses in E-box.
Car locks/unlocks interior lights work but no power to dash although key turns in ignition. 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232011 30th Dec 2013 5:10pm
the battery has to be 100% for all the ecu's to function....i'd test that first.. ... - .- -.
Post #232013 30th Dec 2013 5:19pm
daz62
Apparently the ignition switch can fail, this similar problem to yours ended up being a broken connection in the fuse box.
http://www.landyzone.co.uk/lz/f10/key-turn...22867.html 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #232016 30th Dec 2013 5:30pm
Saltyfish
Battery is at 100% charge. 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232017 30th Dec 2013 5:31pm
Rosco
Any unusual messages coming up as I had a similar issue a year or so ago, but it threw up a ' CODE ----' on the display, Turned out to be a faulty instrument cluster Very Happy
Post #232033 30th Dec 2013 6:45pm
Saltyfish
There appears to be no power to the dash apart from the mileage display. I'm now thinking a fuseible link (no 2) may have blown as this appears to power everthing that has stopped working. 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232036 30th Dec 2013 7:11pm
Saltyfish
UPDATE.
Dash now lit up as it should, engine cranks but won't fire up.
Called out AA they checked for codes and returned crank sensor, ive located the sensor but cannot find a part number on the tinternet to allow me to order a new one. I'm also not convinced its the sensor.
Looks like i'm gonna have to bite the bullet and send it to a garage.
Big Cry 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232133 31st Dec 2013 4:26pm
Saltyfish
UPDATE.
Changed the crank sensor and bingo the V8 springs into life.
Happy days!!
Thumbs Up Thumbs Up 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232627 3rd Jan 2014 5:05pm
did the garage diagnose and repair?
Post #232628 3rd Jan 2014 5:10pm
Welshdragon
Thumbs Up Great news Thumbs Up
One to remember too, as I'm sure it will happen to somone on here, yep bound to be me Laughing If it dont work.......burn it!
Post #232635 3rd Jan 2014 5:58pm
Saltyfish
The AA diagnosed and i repaired.
01 Vogue 4.6.
00 Vogue 4.6LPG.
Post #232909 4th Jan 2014 11:30pm
