Home > Technical (L322) > Frost alarm |
WeeJ Member Since: 12 Aug 2012 Location: Aberdeen Posts: 28 |
Is there a way to change the alarm point at which the frost alarm initiates?
5th Jan 2014 12:16am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
The alarm is to highlight that it could be getting icy, so moving the temperature it goes off would not change when ice may occur, but you'd lose the warning, though I see what you mean. As you can drive, you can prob look out the windscreen and realise it could be icy !
5th Jan 2014 7:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
i dont know how it would affect other systems but you could take the sensor off its bracket ,wrap it in foam and tuck it away behind the headlight....if it works great if it doesnt then its not hard to put back to its original position.. |
5th Jan 2014 10:43am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
You can turn off the cold warning in the CCF files with an iid tool |
5th Jan 2014 10:49am |
as of yet GAP havnt got a tool for the OP's 2012 FF but it is coming soon so a great suggestion Craig.. |
5th Jan 2014 10:55am |
Sorry Stan, guess i should have looked at the age of car
5th Jan 2014 10:58am |
i'm sure it will be included Craig ...strangely mine came on last night and it was only 5 degrees and i never thought of the IIDTool so thanks for the headsup... |
5th Jan 2014 11:10am |
5th Jan 2014 11:45am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Unfortunately the CCF for 2007-2009 doesn't include the low temp warning (or at least I can't find it!).. Not sure about 2010 onwards.
5th Jan 2014 4:05pm |
i have also looked and cant find it , maybe its under a different title...Craig? |
5th Jan 2014 5:19pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I would have thought there were a few systems that were referenced fom the temperature, so it would have to be accurate.
5th Jan 2014 6:05pm |
Im sorry Guys but i think i sold you a dummy
5th Jan 2014 7:52pm |
5th Jan 2014 8:57pm |
Yay! .
5th Jan 2014 9:48pm |
