Home > Maintenance & Mods (L322) > FBH upgrade to "Thermo Call"?
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
With wintry weather on the way I was looking at the Webasto website (I believe they supply the FBH fitted to range rovers). They offer a feature called thermo call whereby the heater can be activated from a mobile phone. Potentially very useful when on a train or similar so the car can be nicely defrosted/warmed up on arrival. Anyone know if this can be retrofitted?
Post #233758 9th Jan 2014 11:45am
GraemeC
Have a search on here - a couple of people have wired GSM receivers into the FHB remote activation circuit, giving them that facility
That said, if its plug and play, I'd be interested depending on cost! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #233759 9th Jan 2014 11:50am
there's one for sale here,
http://www.fullfatrr.com/forum/topic22866.html
Post #233760 9th Jan 2014 11:52am
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
I think SteveMFr was working on something along them lines. Drop him a line ! Thumbs Up
Post #233815 9th Jan 2014 4:43pm
johnf
Thanks, he talks about a solution here:
http://www.fullfatrr.com/forum/topic12516.html
I'm currently talking to a Webasto dealer about fitting an official Webasto controller - the TC3 Thermocall. There are also wiring adapters available for the L322 - looks the neatest way to install and allows use of the Webasto app which deals with the potential timing issue referred to in the above thread.
http://qualityparts.de/uploads/media/webas...g_engl.pdf
The dealer though thinks this might cause a problem with the car shutting down the electrics if installed in an L405 (which I have).
Post #233825 9th Jan 2014 5:27pm
GraemeC
Very interesting John, did the dealer give you any indication of price? (preferable for parts only, seems easy to fit!)
I'd be interested in a TC3 Thermocall with wiring adaptor for an L322 as a 'plug and play' solution 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #233827 9th Jan 2014 5:49pm
johnf
The receiver itself is on ebay
http://www.ebay.co.uk/sch/i.html?_sop=10&a..._PrefLoc=3
about £230. Plus I guess the wiring adapter and fitting - although it may be a DIY job for some.
Post #233828 9th Jan 2014 5:55pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
http://www.ebay.co.uk/itm/GSM-Mobile-Phone...3388eda541
this is the type i have fitted, 3 wires to connect piece of cake £71 with enclosure
can switch FBH on from anywhere in world
just make sure you buy one with an adjustable timer
Post #233867 9th Jan 2014 8:25pm
Andy
Webasto have an iPhone app for their newest one
Post #233874 9th Jan 2014 8:42pm
GraemeC
Ironhorse, that looks a really good solution!
Could you post instructions how to connect up? This looks like a mod I'd like to do, more factory fit and less hassle than wiring a second T90 remote to a GSM timer 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #233901 9th Jan 2014 11:25pm
ironhorse
[img]http://www.fullfatrr.com/gallery/albums/userpics/14187/Alpha_v2_04_F2_07%281%29.pdf[/img]
ill do you a wiring diagram later but hear is the info to have a look at
ok .link dont work for some reason will try later to upload
nige
[/list][/url]
Post #233929 10th Jan 2014 8:42am
ironhorse
link to instructions is on ebay page above and below
http://www.adventcontrols.co.uk/Alpha_v3_01_F3_01.pdf
nige
Post #233931 10th Jan 2014 8:51am
GraemeC
Cheers, instructions look good, only bit I'm not sure on is which wires from the Webastro I need to connect, really appreciate any tips here Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #233936 10th Jan 2014 10:01am
ironhorse
in the boot on the right hand side above the fuse box find a plug with 3 wires
white/green
red/yellow
brown
i cut the plug off and left enough wire on the plug just in case i needed to put it back to standard(when i sell the car),then connected to GSM as follows
brown = connect to "gnd" in the GSM
red/yellow = connect to "+ve" in the GSM
white/green = connect to "no" in the GSM
then you need to loop a wire from " +ve" to "common" in the GSM
very straight forward when you have the GSM in your hand
hope this helps
if you need more info let me know
nige
Post #234010 10th Jan 2014 7:32pm
Andy
I think this would be cheaper for me to do, rather than trying to source T60 bits.
Post #235099 15th Jan 2014 2:36pm
