![]() | Home > In Car Electronics (L322) > Nav screen illuminating whilst vehicle unattended. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Got a call last night from my wife telling me that the Nav screen was on showing the splash screen. It then went off and came back on a short time later.
I've never seen that before. I'll keep an eye on that. Cheers |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
Splash screen is showing every time the system wakes up something is definitely waking it up could be the suspension but also other systems that are connected to the I-bus ( radio,nav,light module,...) if it happens often it wil drain you're battery quickly as it uses several amps to wake the modules. |
External radio interference? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The old favorite water ingress in the LHS of the boot... Check for damp and do a battery reset |
Just been woken by the cars alarm. Bleeps for a few seconds, stops then does it again.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
bonnet alarm sensor Noddy...they get corroded or stuck ...... |
