Home > Technical (L322) > Drivers memory seat
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Drivers memory seat
It's one of those things that's been bugging me for years and I can't figure it out. It doesn't seem to matter wether I lock the car or not but most of the time I go to the car after being parked up, the drivers seat is way forward and at completely different angles to my setting so I have to always press the memory button to put it back even if I've just nipped out the car for a few mins. What am I doing wrong ?
Post #236940 24th Jan 2014 10:37pm
You have memory 1234 buttons and 1234 keys... If your key you are using is key 3 for instance, it will set the seat to position 3 set in the memory. Set number 2 to your position, then if that doesn't work number 3 then 4...
Then you will know which key you have and which memory button it corresponds too Thumbs Up
Post #236947 24th Jan 2014 10:48pm
Shandonman
Thanks for the reply. So what I have done is set the three memory positions on the seat to my preferred setting so t shouldn't matter what key I have. Still when I return to the car, the seat has moved way forwad and all the settings are different I then press 1, 2 or 3 to get it back to the correct place Confused
Post #240857 7th Feb 2014 8:36pm
johnboyairey
i had a similar problem, it turned out that a homeless dwarf was opening up my car and sneaking in a kip! I caught him asleep one morning, and yanked him out of the car!. he said he wasn't happy. so I said, which one are you then?
mmmmm. BEER!
Post #240860 7th Feb 2014 9:00pm
Shandonman
Rolling with laughter
Unfortunately it's Mr Shortarse that sneeks into mine
Post #240866 7th Feb 2014 9:15pm
Then it will be the seat ECU at fault Sad
Post #240891 7th Feb 2014 10:10pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Re: Drivers memory seat
Hi does this help ? It says how to set the memory on the seats;
http://www.landrover.com/imagery/market/us...tart-guide
Post #240904 7th Feb 2014 10:32pm
Shandonman
I have just today after nearly 3 years noticed how the seat does this only sometimes. I could never work out if it was keys or different ways of locking or unlocking and all sorts of combinations of different things that would cause it.
Its only if I open the tailgate.
It just seemed to randomly have moved forward after returning to the car after parking. Sometimes it would be ok, sometimes up against the windscreen. Today when I lifted the tailgate to get something, out of the corner of my eye I spotted the seat moving forward. So now I know what causes it. How to fix it is anyones guess. Weird.
Post #242010 11th Feb 2014 7:15pm
you must have the 'vogue haunted' edition range rover.. Laughing
Post #242023 11th Feb 2014 8:07pm
johnboyairey
WHATEVER YOU DO, DONT PLAY THIS SONG IN YOUYR FULL FAT!
check out the v8 burble at the start.
Post #242046 11th Feb 2014 9:18pm
