![]() | Home > Maintenance & Mods (L322) > heated rear window |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Is the spare wheel well dry? Excess moisture can live in here. But to your question, I rarely put it on due to the A/C sorting out the damp air. |
joebenz Member Since: 14 Dec 2013 Location: United Kingdom Posts: 9 ![]() ![]() ![]() |
i noticed the boot floor was wet the other day when i was changing the inner boot bulb. do you know how do i fix it? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
search 'water shedder' and all will be revealed.. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
or the tailgate seal .
checking now |
so went to land rover and they said that they don't do a water shedder for my car!?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7977 ![]() ![]() ![]() |
I'm sure i posted up a part number for the shedder, just order one of them. Same as my car.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I have the water shedder but I can't find any instructions anywhere how to actually fit it. There is a difference between knowing your sh!t and knowing you're sh!t
one of these threads will probably help,
Thanks... will order tonight |
@rej, if you are still stuck fitting, here is a pic.
Thanks. The supplying dealer is found to try and sort the leak when they take the car back. I will try and got thereafter shedder at the weekend if dry. Only dampness evident is around the spare wheel, nothing obvious in the sides. Is the seal most likely? There is a difference between knowing your sh!t and knowing you're sh!t
Mine has never leaked, did the shedder as a precaution.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Whilst a water shedder may well stop water leaking into a car cascading over the valuable electrical gubbins located in the rear compartment it does not stop the water coming into the car in the first place and in the right conditions going on to form condensation over all the components including those under the shedder.
