Home > Technical (L322) > quiet front pdc
manxaircrest
Isle Of Man 2013 Range Rover Vogue SE SDV8 Nara Bronze
quiet front pdc
Hi all .... have an 09 SE which i have replaced my RRS 07 with .... very pleased an a whole new world i have to say have a couple of issues (nothing major) but one is the front parking bleeper is very quiet and although not the sharpest of hearing by my own admission, you have to turn the radio down / off to hear it when parking .... it sounds like its under the drivers side column ..... replace ??? adjustable ?? any ideas ?? all would be welcome .... very best in advance Brian
Post #239026 2nd Feb 2014 8:04pm
the volume on rear ones are certainly adjustable but afaik the fronts are not..i would locate the 'bleeper' and see if there's any thing wrong with it..the WSM should help you look in the right area..
Post #239031 2nd Feb 2014 8:19pm
T24RES
How do you adjust the volume Stan? Is it with the iid?
I do find the not being linked to the music thing very frustrating and costly Whistle
Post #239041 2nd Feb 2014 8:45pm
correct Ian, the iidtool can adjust the volume on the rears..i increased mine so i have no chance of reversing into anything now.. Wink
Post #239044 2nd Feb 2014 8:47pm
Boat.Buoy
2002 Range Rover Vogue 4.4 V8 Epsom Green
I bought a vehicle with a similar problem once, turns out the previous owner must've thought the beep was a little loud, and covered the unit with some foam/sound deadening! Removed and all was well.
Matt
Post #240491 6th Feb 2014 9:02pm
manxaircrest
never thought that may be an option ...... the simple things eh .. ?? any ideas where the little blighter may be lurking before i go in !!
Post #240827 7th Feb 2014 6:21pm
Boat.Buoy
Have a look under the steering column, just to the left of the interior light..
Matt
Post #240850 7th Feb 2014 8:21pm
Andy
We have a Peugeot Van at work and the radio goes quiet when the reverse bleepers are on. You'd think that technology would be available in Range Rovers by now...
Post #241014 8th Feb 2014 1:25pm
