Home > Maintenance & Mods (L322) > Aux Input?
Page 3 of 3 <123
Andy
Do the early models (2002) play mp3?
Post #244327 22nd Feb 2014 10:31pm
Not sure about the 02 models,
If you load the music onto the cd's as albums, so one folder = 1 album, which you can name, then You can select the album using the touch screen! There is nothing that can't be fixed with a hammer😜😜
Post #244331 22nd Feb 2014 10:53pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I tried the MP3 CD burnt through iTunes and just get Invalid disc appear on the screen Sad
I have however, as a result of this thread, found a rear aux input on my 2006 for my iPod and will be trying it tomorrow thank you Thumbs Up 4.2 Supercharged Vogue SE
Post #244334 22nd Feb 2014 11:01pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Thanks for all your help Bow down Bow down
I'm on nights this week Sad
But off work next week, s0 I'll give it a go (sick of SWMBO griping about no aux, so she can't use her MP3 Player - all she needs to do now is to burn the files off the MP3 player on to Cd's) - Sorted Very Happy 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #244338 22nd Feb 2014 11:14pm
Chauch you will get the error with itunes burned cds, they use a different format, it needs to be a simple file structure with the files simply dragged and dropped onto the disc as album folders, in MP3, shpuld then work There is nothing that can't be fixed with a hammer😜😜
Post #244339 22nd Feb 2014 11:22pm
Chauch
Good man, thank you, I will give that a whirl tomorrow as well Thumbs Up 4.2 Supercharged Vogue SE
Post #244344 22nd Feb 2014 11:30pm
Stan is right it came with Terrain Response , before that it was never standard. 2008 MY Supercharged
Post #244355 23rd Feb 2014 1:48am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have finally fitted my PURE DAB which allows me to put my iPod in the centre cubby hole and control via the controller that I have mounted ear the steering wheel. Will also play from other MP3 players using a standard 3mm jack. Connects via FM as no easy way to link into the aerial wiring but sounds ok to me. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244368 23rd Feb 2014 9:38am
Page 3 of 3 <123
