![]() | Home > Technical (L322) > SORTED: HDC inactive, lowering suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35755 ![]() ![]() |
guessing it could be the battery or a height sensor .............. |
Any loss in power? Could be a split turbo hose as it frequently generates hdc fault message if split. Present :2008 TDV8 HSE
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Battery's a year old but fires up just fine without any bongs, even after fbh been running for half hour.
we've had loads of rain so its possible...its dry today so is it doing it now? |
I'll be going out later today or tomorrow so will find out and report back. 2007 TDV8 Vogue SE Java Black |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I had the same thing happen to me just before Xmas, it had been raining hard and when one of my xenon lights blew up, I got the same. Once I'd replaced the bulb, it was fine afterwards. |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
My guess would be low battery, HDC seems to be the most sensitive to low voltage of all systems on board, if my battery is even slightly low I get the HDC inactive warning when I start.
Thanks for your reply discotigger. The severe rain seems to be a common factor in this.
Well I have had 4 trips since, and it's happened twice. Once was very wet, once was slightly damp so don't think it's moisture related now. Also get a message on the touch screen flashing up something to do with terrain response, but I haven't been able to catch it all yet.
Meant to add that the two warning lights that come up are the dynamic stability control and emergency brake assist that both stay at amber. Everything clears when restarting 2007 TDV8 Vogue SE Java Black |
Found the reason for this in case it helps anyone. My steering wheel has always been slightly offset, which is annoying but I lived with it. Recently my track rod end ball joints have started to go, meaning that occasionally the steering wheel goes slightly more offset. This then seems to confuse the ECUs because from the steering angle sensor it thinks it's going round a tight bend and wonders how that's possible travelling at 70mph!
Glad to hear it's sorted and cheers for the update info. |
MikeC295 Member Since: 24 May 2013 Location: Durham, UK Posts: 32 ![]() ![]() |
I had this exact same thing on mine last year, turned out to be the steering wheel not sitting straight while driving in a straight line. Quite an easy fix with a 4 wheel alignment. |
